Bonstrosity
Thread starter- Joined
- Jun 7, 2006
- 48
As stated in the title I am having some issues at low rpm. The motor starts idles and runs fine however when going to throttle up on the water there is a slight miss around1500- 2000rpm. If I throttle past it, the motor revs higher and the issue goes away.
To give a history this motor recently had the powerhead replaced. The carbs have been rebuilt, they were missing the roller that went on the throttle plate which was replaced. There were also new plugs with the rebuild. I have new coils on the way as the back epoxy area looks cracked on a couple of them. This was an issue with the old powerhead too I assumed it was bc of the missing piston ring and low compression in one of the cylinders.
