1990 Johnson 88 spl
surfzone
I have been having some issues getting this engine to crank. After doing some research on this site I found out about the hold the key down in the on position for an 8 count and then turn the key. This worked and the engine started up, but only for a few seconds and then off it went not to start again. I then thought maybe a fuel issue so I pulled out some fuel and found that it looked brown in color however it smelled strongly of gas and did not have water in it. The fuel has been sitting in the tank for about 5 months while I was doing some body and electrical work. My real question is do I have bad fuel or is something up with the engine? The boat is a 1997 Key West 1720. here's a pic of the fuel sample
Bosunsmate
id replace the gas, or at least try lighting some and seeing how quick it evaporates just left on the ground.
Also to start you prime the bulb tight, you rthen turn the key to crank the starter, you only then push the key in to operate choke.
Once it starts you let go. When it starts to stall again you press the key in- thats whats called bumping the choke.
You do not hold the key in before starting- that loses fuel pressure to the motor and will cause problems
