1990 Johnson 30HP Misses at low throttle
mmataya
I have a 1990 Johnson that misses at 1/8 to 1/2 throttle. (sputters like is it misfiring). Runs fine at full throttle. I replaced the following parts: Fuel tank, fuel hose to the motor, fuel pump, rebuilt carb and cleaned carb, Sync and Link, and new plugs. After I ran it, I checked the plugs and the top one was black and wet and the bottom one was black and powdery like it had been firing. Is the top one not firing all the time. Is the oil mixture too much. I am doing 50:1 for oil mixture. I did the ohm check for the coil and it check out ok on both of them. I checked the resistance of the plug wires and the one that was wet was having a hard time getting a reading on it. Don't know if a bad plug wire would give these symptoms. Any ideas?<br />Thanks,<br />-Matt
mmataya
Re: 1990 Johnson 30HP Misses at low throttle
Well I noticed that a bolt was loose on the head of the engine and water was leaking out from it. I think that I was loosing compression and the bottom plug was burning leaner than the top bacuse the fuel was escaping out the leak by the loose bolt. I tightened it and now both plugs are wet (the same amount). If it is running rich, how do I lean it out. I was told that the needle valves for this engine are fixed (non adjustable).<br />Thanks,<br />-Matt
