1990 johnson 175 problems help
raptorgaeb
whats up everyone got a boat 2 years ago and have been sick of it and ready to just get rid of it ! runs and starts fine don't really know much about these outboards being this is my first one but get it on the water and get about 3/4 throttle and runs fine than it completely stops and alarm sounds contantly.... peeing water replaced water pump and thermastats and still same thing .. after u turn key off and on alawm is still there sometimes even before u run it alarm is on when key is turned on and have to cycle it a few times for it to go away! any ideas ? changed fuel filter im lost and don't know what else I should do please help !
emdsapmgr
Your 175 is a strong engine, in good running condition. It's the later version of the older 235. Lots of cubes and torque. You may want to refer to the original factory service manual in order to work on your horn issue. There are two types intermittent horns-both related to the flow of oil to the fuel pump. 1. Since your issue is with a constant horn, you will want to diagnose for a possible problem with the fuel vacuum switch. That switch will turn on a constant horn if the fuel vacuum reaches a critical pressure and the fuel pump may start to starve for fuel. (lean conditions are bad.) Usually this fuel restriction warning horn will turn on at higher rpm's but the switch could be bad (grounded.) 2. You will also get a single warning horn if the engine thinks it's overheating. This could happen if the temp sender circuit is grounded out, causing a constant warning horn from the git go. 3. It's also possible the horn itself is defective. The horn circuit logic resets itself every time the key is turned to off, so your turning off/on may temporarily clear a fault horn, to have it return if the original horn issue/problem is still not fixed. Best to sit down with the service manual (and the color wiring diagram at the back) and do some troubleshooting.
