1990 johnson 175 GT problem at WOT
5bigfish
I have a 1990 Johnson 175 GT that I bought from a friend. When I bought it it had been sitting for about 2 years. The reason was he had bought it and engine wasn't running correctly long story to short he bought a new powerpack and still didn't run correct and was told it needed a stator.
What I have done: Bought a new stator, new rectifier checked magnets on flywheel, rebuilt carbs, new fuel water separator. Runs with a electronic fuel pump which is new. The VRO has been removed.
Problem: Cranks and idles forever, in neutral and in gear. Will take off get on plane mid throttle fine. Floor it and it Accelerates up to WOT and it is like it has a rev limiter. If I push the key in, while what i though it was bogging it will get worse. Also let off throttle a little and runs fine. I'm stumped can it be getting to much fuel at WOT. Ps.. compression is 100psi all cylinders
5bigfish
4500 but my tack is not working correctly. Needle spins freely turned off.
1983 ercoa 21'
So you feel certain that there's a problem?
or does it feel like the motor is running good but not as fast as you want?
the way I read your description if sounds like you maybe hitting a rev limiter . Look your power pack up on line to see if it has one built into it.
fix the tach so you know for sure what it's doing .
is this problem different than the one your buddy had with it or completely different?
5bigfish
I will check. The motor is on a Ranger 482v 18ft it runs 50 mph when it starts to act up. I would think the boat should run 60 mph. The problem he had it was loosing spark and not start at all.
1983 ercoa 21'
Get the tach fixed and see where your at on rpms you may find out it's proped wrong.
id ask your friend you got the boat from what top speed was for him. You might also ask if he ever changed props.
emdsapmgr
If it's got a factory power pack, it should be rev-limited at 5800. If your carb is properly jetted and you are at high rpms-then you push in on the choke: that will choke (overfuel) the engine and it will cause the engine to slow down. That's normal. The exact way the performance guys know if the carbs are jetted rich enough. Am wondering if the horn works on that engine. That engine has the SLOW feature in the ignition. If the cyl head temps hit 203 degrees, the power pack will limit rpm's to 2500 rpm's. Further, this system is also activated if there is a malfunction of the VRO pump, if it's tank is low on oil, or if the engine has high fuel vacuum, as measured by the engine's fuel vacuum switch. If the horn works and you've not heard the horn during your testing-that's good.
5bigfish
Ok just an update. My electric fuel pump was 2 - 4 psi after talking to a couple mechanics it was not strong enough to keep up with the carbs at wot. I bought a 4 -7 psi fuel pump and has fixed the problem.
