1990 Johnson 155 trim/tilt failure
Mgsmith
I have a 1990 Johnson 155 commercial on a 1989 Chaparral 204 Fisherman and the tilt/trim quit suddenly. Working on the engine on the trailer, lowered engine to apply muffs, finished working, tried to raise - no go. Tried to lower, no go. Do have clicking at the relays at the back of the engine. Can you folk help?
Thanks,
Mike
boobie
Re: 1990 Johnson 155 trim/tilt failure
Give the tilt/trim mtr a few raps with a small hammer once and see what happens. It may be just a stuck brush.
Mgsmith
After consulting the actual MANUAL, I see there is fuse identified in or near the relay junction box at the rear of the motor. Will investigate. Anyone ever seen this fuse? The wiring diagram indicates it's on the hot lead to test point 1 in the junction box. I can't find the physical location of the fuse. Any ideas?
Mgsmith
After running through the complete electrical diagnostic and proving the pump motor is functional, it seems that the sending unit and 25 year old trim gauge are not. Can the sending unit failing cause the pump to become inoperable? I thought the sending unit only "told" the gauge the relative position of the trim/tilt of the motor based on resistance in the unit. Can anyone clarify?
Thx,
Mike
