1990 Johnson 150 no- start (sometimes)
montvaleplace
I have a 18` bass boat with a 1990 Johnson 150 that i have owned for 2 yrs. It was starting ok the first year but last year it was cranking but not firing. If I pulled the plug boots out to the end of the spark plugs sometimes it would start. After the first start-up it would start all day no problem. The first time I started it this year it was ok but now it is doing it again. After cranking it for a bit with no luck I put a spark tester in line with one of the plugs and cranked to check for spark, it started . Has anyone heard of this phenomenon?
jakedaawg
Time for an open air gap spark check with appropriate tester set ton7/16"
also do compression test
also clean all grounds including power pack and coils. Throw away any wing nuts on batteries.
might post a model number. I can't remember what they offered at 150 back in 90.
