jakethebrake
Thread starter- Joined
- Jul 5, 2009
- 3
I have a 1990 johnson 150 that will not go down when the trim switch is pressed. I tried all switches on the boat/throttle and the one on the motor itself and all are "dead" in the down position. The engine will raise will all switches. So as you can imagine I trailered home from the lake with the engine all the way up. Any idea what may be causing this?? Thanks in advance for any help!
