gnarbrah
Thread starter- Joined
- Sep 20, 2007
- 140
Hello all - not exactly sure of the year of this engine (ID plate is missing) but I think it's a late 80's early 90's. Engine runs great has130psi both cylinders BUT the wonderful trim tilt motor died. I've read and watched videos to the ends of the internet and I've learned I need heat, big hammer, penetrating oil and patience to remove the upper pin to get the motor assembly to tilt so I can access the back screws. That being said I believe my engine is "special".
It would appear that I do not have a manual release that would allow me lift the engine and block it to relieve pressure on the pin (step1 correct?).
Also it appears that my upper pin has a bolt threaded into the starboard side and just a "cotter pin" to secure the pin on the port.
It appears my only hope in removing it will be hitting it on the starboard side and forcing it to port. My plan is to remove the starboard side bolt, get a drift and start wailing away at it. Any suggestions are GREATLY appreciated!! Here are some photos:
