ou18
Thread starter- Joined
- Jul 24, 2008
- 40
Hi All,
This is my first post so Ill try to explain as thorough as i can. Im having an issue with the following boat
1990
Four Winns
Horizon 180
OMC 4.3L Engine with Cobra Outdrive
Recently i went to put the boat in the water and noticed that none of my gauges worked, my stereo didnt work, none of the dash switches worked, (bilge, nav lights, blower, etc). Boat starts and runs strong. But none of the other electronics seem to be working. Battery is good. I have not added anything to the boat. I checked the fuse panel under the dash, all fuses are good. I even pulled them out and wiped the off with a dry cloth to make sure there was no corrosion on them.
I guess my question is, where to look next. Im not an electrician but I am mechanically inclined. I do own the actual OMC factory manual. Should i be looking toward the engine area on this. Are there any other fuses not under the dash i should be looking for...
Any help in getting my instrument cluster and switches working again is greatly appreciated...
Thanks
1990
Four Winns
Horizon 180
Thanks
