1990 force 90hp
normbarb
I have had the motor to a marina and he said the problem is in the ign. system. Sai it cost up to 1000 to fix. My brother and i would like fix it ourselves . Since it looks like it will just be replacing parts. But we need to know where to start. The motor has been hard to start for awhile, so I had it tuned up for the summer.It also would not start after running for awhile. tune upped, but still having the same problems. Mech. said it must be in the ign. system since it acts up when it gets hot. Stator, trigger, what ever.
12Footer
Re: 1990 force 90hp
It could also be water getting into a cylinder or two due to a blown head gasket or exaust port plate, it could be a tank venting problem at the fuel tank (loosen cap to test this)..It could be the fuel pump failing or a plugged fuel filter.<br />And of course, it could be the stator,trigger,switchbox like your mechanic said.<br />He will have to troubleshoot it, as will you, if you decide to go that route. You can save a bunch of money using your own shop,tools,parts and labor (as you know). And if you can work on your car with any degree of confidence, you can do this.<br />But do yourself a favor by getting the shop manual before you dig-in. I promise you, it will save you time and money.<br />As for the guys and gals here on iboats, they'll try too. Troubleshooting can get frustrating sometimes,, and patience is more than a virtue, it's a requirement :rolleyes: <br />The electronic ignition system parts on outboards are stupidly expensive,so you want to test each component forwards and backwards to be sure the old one is faulty, before buying new ones.<br />The 85-150HP Force engines have a tendancy to develope leaks in the exaust port plate gaskets.Look for a new-looking plug or two. They may be steam-cleaned due to this water.<br />The plugs say a bunch about what is happening inside an outboard.If the plugs have more than 1 hour on them, they should show a color other than white...A nice coating of "powdery" dry black, brown or gray is normal. White, shiny clean is not,after a period of running.<br />A compression test cold, and one when symptoms occur, may give a clue as to what may be up wirh it.
normbarb
Re: 1990 force 90hp
I have started the motor and the #3 was not firing. I moved the plug in wires in back of the CD. and it is firing fine now .we have checked the ohms from the trigger and it seems to be low. What parts need replaced.
lonewolf5347
Re: 1990 force 90hp
SO YOU SWAP WIRES FROM THE STATOR TO A DIFFERENT CD PACK. NOW NO #3 FIRES DID 1@2 GO DEAD?
Deerdog
Re: 1990 force 90hp
I might be missing something here or read the post wrong. I agree with 12 Footer completely. YOu got to get the manual first. My question is:<br /><br />Is the mech who tuned it (from teh sounds of your post he didnt do that good of a job) the same one who is now telling you the "ignition" needs to be replaced.<br /><br />Deerdog
jimdi@localnet.com
Re: 1990 force 90hp
Lonewolf sent me a great troublshooting guide for Force electrical - perhaps he could send you a copy as well.
