HAMMER1111
Thread starter- Joined
- Sep 23, 2013
- 4
Hello All:
I am new to the boat world and have a few questions about a boat I just got. I was lucky enough do get a boat for free. A 1990 Maxum 17' bowrider. Hull and interior is in great shape. May need to put rings in the engine but not sure yet.\
Questions
1. When the engine is in the up position it creeps down. Does the pump have an internal check valve or does the seals in the cylinders need replacement? I cant find a breakdown of the pump anywhere on the net.
2. I noticed that the 1 cylinder does not have hydraulic lines attached and no hole for lines. Is that a helper cylinder only?
3. What do you think is the best thing to do about the engine. Should I attempt to break the block and install new rings? Should I buy a used powerhead? Money is tite but I never took a block apart. I can fix all other problems with cars and trucks but never had an engine completly apart like that. Any feedbackI would appreciate.
Thanks
Questions
Thanks
