Derrick Fronckowiak
Thread starter- Joined
- Jul 15, 2015
- 112
I own a 1990 Force 90 and have been trouble shooting the ignition system. It was running but WAS firing only on #2 and # 3 cylinders, but not on #1 (I verified with a timing light). I read out resistance on the trigger, the stator and the coils and all read within specs/limits, no opens, no shorts. Also got DVA test leads and checked DVA voltage at the stator, all within limits. At that point I was done monkeying with it for the winter, I winterized and let it be. A few weeks ago I was getting things ready to go for fishing season. I went to start up and had NO cylinders firing. I pulled off the flywheel to discover that the flywheel's center trigger magnets and layered plates were damaged (due to physical contact). I got another flywheel and installed it. Now it's firing on cylinders #1 and #2, but not on #3. What the.....? Now I've got sparks, but it seems the original problem "moved" from Cylinder #1 not firing to #3 not firing. I'm frustrated and baffled and really want to get this fixed, but don't want to randomly change ignition components. Anybody got any ideas about anything else I could/should check?
