JohnWaynne
Thread starter- Joined
- Jul 4, 2022
- 23
Hi, I'm new here and been boating 2-3 years. After taking my boat out I discovered the prop showed signs of wear. It looks like something wrapped around it and damaged the prop and bearing cage, or maybe the bolt vibrated out and damaged the back of the prop Not sure, but the bearing cage is cracked and missing a bolt.
My question is is there a special tool needed to pull the bearing cage off and install a new one? It's cracked and there maybe water in the lower unit oil. I haven't looked yet, but I know the oil needs changing anyway.
I'm planning to replace the bearing cage kit, add new oil, and install a new prop. Any thoughts or advice for this repair? Are there other parts that should be replaced in the lower unit? Thanks for any feedback.
