fishnfool93
Thread starter- Joined
- Aug 10, 2019
- 1
Hey guys. New to the forum, but I've definitely read through some posts in the past. I've got a 1990 Force 50 HP (507Y90C) that I picked up last year for $450. Guy I got it from had taken great care of it, regular changes of fluids, impeller etc. I added a telltale to the motor a few months back, and it works GREAT. However, I had the boat out last night and noticed that the telltale water was pretty hot. Didn't have a thermometer on hand, but definitely hot, and much warmer than usual. The stream strength was still good, and I didn't get an overheat alarm or anything after trolling (at idle, or just above) for ~3 hours. Stream temperature stayed hot the whole time, but the motor was running fine.
You guys think that the motor is overheating, or anything needs to be checked/replaced? Figured the impeller is fine because the stream is strong, but maybe the thermostat is gummed up or needs replaced. Thanks in advance for your help!
Robert
Robert
