1990 Force 150hp running poorly!
humphriess
I have a 1990 150hp Force o/b on a 19ft Bayliner Capri & every time I put the boat in the water & start moving, my engine starts acting like its missing then starts loosing power. While trying to travel at a constant speed, the engine's power will increase & decrease without even touching the throttle. It gets worse the longer I stay out! I buried the throttle to see what would happen & the engine kept jumping to different speeds like it was getting air in the fuel line or something. <br />It runs great when its in my backyard while in neutral & in forward & reverse, but as soon as I shove off the dock & make it push the load of the boat, it starts acting up. I just siphoned out all the old gas & put fresh gas in so that shouldn't be an issue. It has brand new spark plugs & my mechanic said the compression was fine. :confused: Could an air leak in the fuel line cause this or do I have bigger problems? Any help would be grealy appreciated!<br /><br />Sharkbait
Markas
Re: 1990 Force 150hp running poorly!
I have a 92 Force 150 with an Autoblend II oil injection. I had a similar problem caused by a combination of 1) loose fuel line connection at Autoblend on the inlet (bigger hose) coming from the gas tank, and 2) a collapsed hose barb on the plastic part of the autoblend. I fixed it by putting a small plastic tube inside the plastic hose barb and retightening the hose back onto the autoblend. Exact same symptoms you describe before/ perfect operation to WOT in choppy waters after.
humphriess
Thanks for the input! My mechanic told me to replace a 1/4" fuel hose & primer bulb running from the splash well connector to the engine with a larger 5/8" hose because he thought it was restricting the fuel intake to the engine. However, I was unable to do so because it clearly was designed for the 1/4" hose. The hose had a small shutoff value as well so I removed that last night. I also discovered a couple of small holes in one of the fuel lines running into the choke assembly so I repaired that. I checked all the other visable hoses in and around the engine & didn't see any more obvious leaks. The problem only happens in the water so I was unable to find out if this worked last night. <br />This afternoon I'm going to back the boat down into the water, crank it up & put it in forward a little while its still on the trailer & one by one remove the spark plug wires to test if one of the carburetors is the source of my headaches.
oogaboga
shark ,Ive got the same motor and yr. and mine did the same but my problem was fixed with a new stator 140.00 been fine since.look under fiywheel and see if there are any burnt or discoloring going on.
Deerdog
I also have the same motor but the 89 version. I also had the same problems - twice, a few years apart. The first time it was the stator. The second time it was a fuel pump. In both cases compression was great and it ran fine until you got it out on the water and put a load behind it. Hope you get it fixed.
cinder1995
Mine was also the stator. But it didn't need replacing, I just fixed one of the wires coming from the stator.
humphriess
You guys were right on the money!<br />I had to replace the stator along with one of three power packs. I also corrected several other wiring problems associated with the other power packs and replaced a couple of spark plug wires. She's purring like a kitten again! Sorry it took so long for me to response. I certainly appreciate all the advise! :)
