1990 Force 150 ignition stator shot
jgussie
Does anyone know where I can find the schematics (manual) online to replace my ignition stator on my 1990 Force 150?
fucawi
Banned
Re: 1990 Force 150 ignition stator shot
loads of manuals on disc on e bay ..then for a few dollars you have it for ever...should be a straight one to one swop ..take photos and notes on wire colours ..
roscoe
Welcome to iboats jgussie.
Looking for diagrams of parts and part numbers??
http://www.crowleymarine.com/mercury-outboard/1116.cfm
looking for replacement parts?
http://www.iboats.com/Force-Outboar...3451528--**********.891732954--view_id.271715
Please take note, the replacement parts may be different, have different wire colors, and have additional wires.
Follow the directions carefully. Some may include a "candybar" converter.
Looking for an online wiring diagram? Never seen one.
Someone was selling online access to a manual, Seloc ?, as an annual subscription.
In my opinion, the Seloc manuals are pretty much riddled with errors and lacking crucial information.
Best bet is to buy a Clymer Force repair manual, or a factory service manual.
http://cgi.ebay.com/ebaymotors/Forc...Accessories&hash=item3f09ddac80#ht_624wt_1167
http://cgi.ebay.com/ebaymotors/Forc...Motors_Manuals_Literature&hash=item53e8ebd58c
jgussie
Thanks for the replys...replace the stator, but I am still not able to fire her up. There is no current going to the spark plugs. So far I have done the following:
Checked trip breaker
Checked Fuses
Replaced relays
Replaced ignition stator
Pull the plugs to make sure there was nothing inhibiting a spark (e.g. oil)
Does anyone have any ideas on what I should try next?
bentle
Look for a safty kill switch either by the key ignition or by the throttle shift housing. If this is activated then there will be no spark. Also could be a neutral saftey switch and this would be located next to the motor somewhere at shifting cables. This one keeps you from starting while in gear. Both can kill power to coils to prevent starting. Check for loose or broken wires or defective switches on both.
