1990 Force 120
csbender
The Buzzer Went Off The Other Day Just Before I Got Back To The Dock. Water Was Not Coming Out Of The Motor. The Next Time Went To Take The Boatout,the Water Was Coming Out Like It Usually Does. I Let It Run For 30 Minutes And No Alarm. The Next Time Out, Started The Boat At The Dock And Let It Run For 5 Min,water Coming Out Normal. Then The Buzzer Goes Off Again Check The Motor And Water Is Still Coming Out. What Else Could Be Triggering The Alarm To Go Off?????
roscoe
Re: 1990 Force 120
clogged water passages or a failed thermostat.
