1990 Force 120 tach
Ron Medellin
:confused: With the motor ideling at about 700 rpm the tach regesters OK but when I go twards full speed tach meter goes all the way BACK to zero. Everything els works fine. Help.
rickdb1boat
Re: 1990 Force 120 tach
Look for loose connections at the Tach. Sounds like either a vibration problem or a bad Tach. Also, what are your volts reading at full speed??
Ron Medellin
Thanks Rick, I will check both, and or replace the tach.<br /><br />Ron in Texas
