FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
I saw on my door jam that rears are 80 lbs and front 52 lbs? I have the stock wheels and tires, 16". For an unloaded bed with topper shell, is that the pressure I should run? Thanks, Heinz
I run about 50psi on all fours until I need to haul a heavy load, then I'll pump the rears up some. My pick-up, which is the same as yours, beats me to death when I forget to let the air out after a heavy load. I'll use up to 90# in the rears depending on the load. Chief
I concur with Chief. 50 lbs all around for unloaded running. Any more than that you'll shake your teeth out, have no traction, and wear out the center tread of your rears VERY fast. Next time you fill the bed to the top with gravel, crank 'em up to 80.
I asked at the station (years ago) and they said the same thing. Run 50 lbs all around for a better ride and pump them up to 80 or so with a heavy load. F250 also. Or 2500 fer them chebby guys
