1990 evinrude90hp trim motor
iamcanadianfisherman
my power trim and tilt stopped working so I pulled the whole unit out thinking it was the motor but after booking it up directly to a 12volt battery it works fine can anyone suggest what the problem might be?thanks...I was thinking the relays but not really sure
OBJ
Did the TNT stop working in both directions? Have you checked for power to the relay's? If the unit stopped working all together, I would suspect a power supply issue.
Yes it did stop working in both..but after I pulled the motor tried it on a battery and spins freely in both directions
