1990 evinrude xp150 fuel alarm
thegr8cody
I have a 12 gallon tank in my boat at the moment. I swapped out the aluminum 20gallon tank. right after doing so the fuel alarm started going off. put my dads portable 6 gallon in the boat with his hose and it ran fine. I figured maybe it was the new tank. I put his hose and bulb on my tank and it ran fine. So I figured maybe the fuel water separator. got a new line and ran it straight from the tank to the bulb. Alarm still goes off........ my bulb does not suck flat. but I only have about 18" of hose after the bulb so I'm pretty sure that's not the issue. only thing I can think of is somehow its in the bulb?
dwco5051
When you pump the bulb with the fuel line disconnected from the motor does it give you full flow into a jug or can? Also if you work on outboard long enough some day if you haven't done it yet you may install the bulb backwards. It sounds like you may have a defective bulb or you got some crud in one of its check valves.
emdsapmgr
Are you running this V6 on a 3/8" fuel hose? The ball valves in older hose bulbs can act up and restrict fuel. Your factory hose bulb should have yellow plastic hose ends on it.
