1990 Evinrude with 150 low compression
bakerjw
Greetings again. I picked up a Stratos 1850 CC a month ago and have been going through it to get it in as optimal condition as possible. We all know that there is nothing worse than an unreliable boat. The outboard is a VE150TXSEB.
After replacing the water pump, thermostats and flushing the engine I took the boat out on our nearest lake. The motor will run 4600 to 4700 RPMs at full throttle and get the boat up to 37 MPH or so. It has a 14.5" x 19" prop that is a bit nicked up so I don't think that it is over-propped.
Friday I did a compression check on all 6 cylinders while it was cold and read high 70's to low 80's on all of them. I know that is low and is probably indicative of a tired motor. I've seen some suggestions about running SeaFoam to sometimes boost compression and I even saw someone mention replacing the head gaskets as a potential fix. Call me a skeptic, but I typically don't buy into mechanic in a can fixes.
Any thoughts other than a tired engine?
Since the compressions are all fairly even, I don't have any major concerns as far as it being terminally ill. My plan is to just run it over the Summer and do a rebuild over the winter months. I might be able to find a replacement engine, but if I do the rebuild myself, then I know what I have rather than picking up another motor with many hours on it. Without looking at the cylinders and running a bore gauge through them, my plan is to go ahead and have it bored out and pick up one of the parts kits with oversized pistons. That is some time off though.
Any advice is as always... Greatly appreciated.
Watermann
Re: 1990 Evinrude with 150 low compression
Sounds like you know what your doing, a rebuild is the fix. I agree with you about the mechanic in a can. I would rate Seafoam as maintenance, not a fix for anything. New head gaskets would be a ton or work and you would just end up with "new head gaskets".
Post up some photos of your boat if you have a chance.
JB
It is okay as is. Those V6s were built with low compression. As long as all are in a 10% window it is a go.
boobie
Agree with the above but you should do something to get the rpm up. Is the tach accurate ??
bakerjw
I would not have expected that. Good deal.
I haven't verified the tach, I am only assuming that it is accurate.
The one thing that I have not yet checked is spark on all of the cylinders. I could easily have a dead coil or bad plug wire. That is next on the agenda.
There's a local outboard mechanic who is supposed to be really good. I'm probably going to have him do a quick run through on it.
Thanks again guys!
