1990 evinrude vro fuel pump
bcook204
Hi All, I have a 1990 Evinrude model E150STLES. I need to replace the vro fuel pump, Could someone tell me which vro to purchase. I did the research and it seems that model 5007423 is the one I should purchase. But my brother says it model 5007420 because it is 4 wire. I did look at the vro on my boat and I saw 4 wires coming out of the vro.
Which is right and what is the difference, they both look almost identical.
Thanks in advance
bcook204
Thank you flying scott, it's down time here in MD and am doing some maintenance work.
cfauvel
Either pump will work, just find the cheapest one possible online....
5007420 is just the 4 wire pump nothing else
5007423 is the 4 wire pump along with extra stuff to convert your three wire engine harness to a 4 wire system.
the extra 4th wire is a purple wire that is hooked up to the distribution block's purple wire, which is a 12V ACC that is on only when the key is ON.
both kits provide a new pulse limiter.
PM if you want to know the cheapest place I found a new one.
