Hi, new to the forum and ran into a bad situation. I was out puttsing around very slow in a 1990 evinrude 2cylinder 2 stroke 40hp (serial number j40elesr) and the engine stalled out and started steaming. Upon pulling the engine cover off in the middle of the lake, the thermostat fell off. I was pulled to shore and noticed that the thermostat blew out of its housing and ruined the threads. I'm assuming thermostat stuck closed and the pressure blew it out.
Did a compression test 0psi on both cylinders.
Removed cylinder head and head gasket as well as cylinder both looked perfectly fine (no visible gouges, odd wear)
Ordered a refurbished head (old head was junk from thermostat issue)
Ordered new head gasket from the local marina
Put oil in the cylinders
Reinstalled new head and gasket and torqued to 16 then 20ft/lbs in the correct inward to outward spiral
Checked compression, still 0psi
Thought gauge was broken, installed spark plugs and cranked it but it didnt fire up
Could my pistons/rings be fried with no visible cylinder damage? I wish this thing had removable cylinders like a dirtbike because I wouldve just pulled them to check the pistons/cylinders more thorough... Thanks in advance!
