Marc Lindsay
Thread starter- Joined
- Jul 1, 2014
- 5
Hi:
I?m having an issue getting the engine up to speed. At full throttle I?m only getting up to 7mph (usual was around 35mph), my tach hasn?t worked in years so not sure the exact rev?s.
Problem initially started when I had a bad water pump and engine overheated kicking into low rev?s. Replaced water pump and thermostat and now this issue has come up.
So far I?ve done the following:
Soo. My thought now is that maybe it?s an ignition coil or the power pack. Any suggestions on some other possible (easy) checks? I may just buy a power pack on ebay and if it?s not the issue, look to resell it.
Any help is greatly appreciated..thank you!
- Fuel- Changed out fuel, also tried pumping fuel bulb and pressing in electric choke, made no difference (although the electric choke gave a little higher rev it was barely noticeable).
- Rebuilt Carbs ? don?t think this could effect it, but could a misadjusted low speed/idle screw or float position cause this issue? Couldn?t find how many turns to start the screws at so set around 2/1/2 turns out.
- Drop cylinder test- basically pulled each plug wire while at idle. I was told it should stop running (or atleast hesitate), but when done it just kept running with only slight hestiation. Also started it with only one spark plug attached, so seems the cylinders are all getting gas and good spark at idle.
- Compression is around 105-110 on each cylinder, and did a spark test and it is getting proper spark at idle.
