1990 Evinrude 60H won't idle
daisycochran
I have a 90 Evinrude 60h that sat out for 3-4 years. I have rebuilt carburetors, replaced VRO with regular fuel pump, replaced fuel hoses, new plugs. Will run at high speed, but won't idle. I have a manual, but can't find any more info to help.<br />any ideas?
ob
Re: 1990 Evinrude 60H won't idle
Assuming that the compression is good on this engine your symptom sounds like one of two things.Either restriction in low speed orifices on carbs (don't know if your particular model has adjustable idle mix screws),or the carb linkage is out of adjustment.There should be a roller on the linkage that should be inline with a scribe line on the fiber throttle cam and "just touching" when controls are in neutral.What sparkplugs are you using?
