donnyrogers123
Thread starter- Joined
- May 29, 2016
- 8
Model TE25ELSE
I am having a misfire that is driving me nuts trying to get to the bottom of it . A little history on the motor it was last ran about 10 years ago and parked for a stalling issue and was drained and sealed up and recently given to me. Motor starts and idles with a slight miss here and there and when u throttle up it misses and backfires a bit and shakes a lot. I had done some troubleshooting and am at a loss for what else to try. This is a UFI engine under flywheel Ignition and I have had the flywheel off to check items under and everything looked good key was not sheared before and miss was there before I took it apart. So far items I have had to replace were power pack trigger got hit by flywheel bolt was loose put new oem champion spark plugs gapped to .040 checked coil packs using a multimeter and got 263 off lead wire peg to ground for both checked warm compression and cold compression both are within 1 of each other warm being 117 each fuel mixture is 100:1 tried to adjust low mixture screw in carb out 1 ? and the miss continues I have read that this timing is correct as long as key isn?t sheared the only thing I had left is plug wires witch I have on order but tried some other ones and still had same issue. Sorry for the long paragraph but I am at wits end with this miss and cant figure it out I also after running with new plugs found one is wet and the other one looks carbon covered Thanks!
