1990 evinrude 175 hp vro using to much oil
J.A
The last time I ran my boat the engine used almost two gal. of oil for about 40 gal. of fuel, it smoked real bad. After insp. I found a broken lead with two purple wires on my warning horn. Could this make the pump, pump to much oil or is it something else, my engine has never used that much oil. Thanks.
marinegrh
Re: 1990 evinrude 175 hp vro using to much oil
have pressure and vaccum test done on tha pump, or just eliminate it completely and pre mix, those pumps are a good penny as far as cost, most of us just premix, unless you have a reputable dealer they can rebuild it if there is a problem, but most wont due to warranty. those purple leades are 12 vdc for the warning horn to operate, the pump operates off crankcase pulse/pressure and vaccum, and diaphrams, sensors are on the system to let the operator know of a lack or oil, no oil or fuel restriction if equipt. what year is you engine, is it an ois <br /><br />good luck
