1990 evinrude 150 hp v6 starting
bcook204
HI all. I have a 1990 evinrude 150 hp v6 that runs absolutely great. Except when I need to start it up after warm up I need to trim it up a little so it will start. I have no problem during this but just wanted to know if this is normal.
interalian
How's the compression? And when was the last time the carbs were R&R'd?
emdsapmgr
I don't have to do that with my engines. When you trim your engine up, that action reduces the backpressure of the water at the prop. Less water trying to keep the exhaust inside the prop, the easier it should start. Engine compression can have something to do with this, so check it.
bcook204
Engine was just rebuilt. Carbs also. New plugs. I am currently running it on 100:1 fuel ratio. For break in.
emdsapmgr
Also possible the floats in the carb bowl are not adjusted correctly. When you tilt the engine, it gets gas. When it's vertical it may be starving for fuel. You might also find that to start it when vertical, that you could prime the fuel hose bulb to get extra fuel into the carbs. In any event, it's not normal to prime it each time you start either.
interalian
I'd say the carbs will feed the jets best when level, and that they're designed to fuel at significant angles. I'd agree that maybe it needs the bulb pumped, and that that wouldn't be normal.
OP: are you raising your idle for warm re-starts? I've always found it necessary on mine unless the re-start is within a very short time since running.
bcook204
Okay, it sounds like the carbs. But someone told me it could be a fuel problem. Possibly a bad gas line or clamp getting air in. What are your thoughts?
interalian
Thoughts?
Try pumping the fuel bulb before your next hot start. Does it take more than a squeeze to firm up?
Have you tried raising the idle on re-start?
If you had a leaky hose somewhere, squeezing the fuel bulb would show you the leak.
emdsapmgr
No way you'd have a fuel problem or a fuel leak if the engine will run all day at WOT.
