jdlloyd_iboat
- Jan 15, 2006
- 52
After 2 seasons out of the water I decided to prepare my motor for fishing. First step, get the motor started. Found that my carbs were likely gunked up and decided to remove and clean and rebuild if necessary. Middle carb needle would not seat and was dumping raw gasoline out the intake (my first clue to a problem with fuel delivery). I removed the 3 carbs and disassembled the offender and its float was stuck to the bottom of bowl. Ok not a big problem but at least cleaning req'd and I will inspect the other two. However, in fooling around with the fuel line from the VRO2 I managed to dislodge the plastic nipple on the top of the pump (the gas/oil mix line that goes to the manifold). I looked at it and it appeared that it broke off cleanly. Is this a mechanical fitting? That is, does it just snap on? Or have I broken a glued on fitting? I cannot imagine it being the former. I really do not want to have to buy a new pump. Can it be fixed in any way such as with a gasoline resistant epoxy like JB Weld? I presume this is a safety critical fitting so I want to do the proper thing.
