SSJMaestro
Thread starter- Joined
- Nov 17, 2008
- 3
Hello,
I will try to make this as clear as possible.
I have recently come across a 1990 90hp Force L-Drive.
When I originally tried to start the motor, the starter wouldn?t kick out. I manually engaged and lubricated the shaft.
I attempted to start the engine again. This time the starter engaged but turned the flywheel very slowly. I trouble shot the starter and everything seemed fine. I removed it and bench tested it and there were no issues. I took it apart and cleaned the brushes and reinstalled everything.
When I started it this time it cranked better but still felt slow. After further troubleshooting I removed the flywheel to find some internal components (shims) to be damaged. I replaced the flywheel.
I tried starting it again, the cranking was better but still it wouldn?t start. I removed the spark plugs (which were corroded) and found water in my 3rd cylinder. I removed the head, cleaned the cylinder walls, removed as much water as possible, lubed the cylinders, cleaned mating surfaces, reinstalled gasket and head cover, torqued accordingly and installed new spark plugs.
The engine now turns over very quickly but will still not start.
This is where I stand now, I would like to get any ideas that anyone can offer. I am open to all advice.
