rubenjs2784
Thread starter- Joined
- Apr 18, 2005
- 25
OK guys, here is my situation. Just bought a 1990 18ft Capri with a 90 hp force engine. The engine has a brand new power head, and was broke properly. I have all paperwork on the rebuilt head. This was in 2001. New Mexico has been suffering a BAD drought the past few years and of course no water in the lakes, so it has been sitting since then (covered). The boat was a consignment and the boat dealer had a pit, and ran it and it ran fine. Compression is good. What I did was drained all of the old fuel, cleaned out carbs(dropped the bowls cleaned out) sprayed carb cleaner in carbs. Replaced plugs. Replaced with 89 octand gas (50:1) Merc oil. This is were I went wrong. While looking at the carbs, I noticed that when I went to full throttle in gear (not running of cource) they did seem to open up all the way, about 80%. So I stared ajusting the trottle linkage to give a little more. But inturn timing and carberation work together. So after calling the local boat shop come to find out doent need to open up all the way. Hoping I didn't mess it up to much I stared it up (with muffs) and started easy. and ran fine on the hose as they all do. Went to the lake and stared fine as for going into gear. When I give a little trottle bogs down and dies. Tweaked with the carbs, and timing (free hand not good I know) and not much improvement. Stars fine but still bogs down. Smoking alot(rich), gas dripping out of front of carb (carb cover off) and when giving trottle misses before it dies. I know ive tweaked this thing out not for the good, beyond imagine. But she still starts. Any help from you guys would help immensely. The boat shops here are all backed up till mid June, and they were my only hope. I kind wanna get her out again before then. Fuel Pump? Carb Kit? Timing? Sorry for the novel.<br /><br />Thanks,<br /><br />Ruben
