1990 70HP Evinrude
williamfw57
I would like to replace the VRO Fuel Pump with a pump that does not have VRO ,,,,,Its a Premix now..... What year or pump will work Thanks
Honorary Supreme Mariner
Re: 1990 70HP Evinrude
A 1983 model pump will work.-----------You may need to make or order the bracket to mount it .--Or simply ty-wrap it in place.----Or look up the pump / bracket for a 91---- 3 cylinder 65 HP commercial model as they did not all come with VRO.
175se
just a thought, what about the pre-mix conversion kit(3 cyl and larger) little pricey, but goes the same place.
williamfw57
Thank you
The VRO pump is elegantly simple to take apart for inspection.---------If you insist on replacing the VRO pump then it is cheaper to go with the 65 HP pump !-----Repair kits are available for those 65 HP pumps as well.
