1990 70 hp VRO tilt trim actuating backwards
89 Bonito
So I'm new to the forum so I'll try and give a quick diagnosis and explain as best I can, but I think the pictures will explain it better. When ever I go to trim the engine down it sucks in the right trim ram, then once it's fully in it starts sucking in the left trim ram, then once that's fully in the tilt finally starts to go down, but then when the tilt gets halfway down, it starts pushing out the right trim ram and then the left ram and then it goes down like it normally would till it bottoms out. (Side note) when i start to tilt it down with the switch I can push the motor down just a little bit until it hits a fluid pressure then I hit the switch again for a second and I can push it down again.
Fed
Could be tight in the tilt shaft, grease the 2 nipples at the front.
Joe Reeves
When all is well....... The tilt down mode works initially via gravity, NOT hydraulic pressure UNTIL it lowers to the trim range, then hydraulic pressure takes over.
The problem is that the steering tilt rod is seizing up and preventing the engine from dropping down via gravity. Loosen one of the tube retaining nuts (either side), then take a piece of 2x4 or section of wood of your choice. Hold the wood against the engine steering swivel bracket close to the tube and belt it with the biggest hammer you have to sort of jog it sideways to loosen it up.
Spray WD40, penetrating oil, something to help loosen that seizing. Let us know how you make out,
Joe Reeves
Hmm, this area (post entitlement) doesn't seem to be recording the replies properly!
