1990 60hp Johnson difficulty starting
dinghyracer
I went to the boat this morning and tried again nd the solenoid clicked I removed it to connect the fuel lines back to it and when I reinstalled it there was no click😕 I will try using the tach wire or a jumper wire straight from the key switch to the primer solenoid
Willyclay
First, I hate electrical problems especially intermittent ones! Now, my experience with something similar on an older Johnson V4 that just about drove me nuts. Your motor's wiring harness should have a 20AMP in-line fuse just like mine. It tested ok for continuity but I finally realized it was not allowing the proper current to flow. The problem I discovered was corroded wiring on each side of the in-line fuse holder. Cut out the old one, spliced-in a new one and never had an electrical problem again while running that motor for many more years. It's usually the simple stuff. Good luck!
dinghyracer
Ok getting really frustrated now. 1st of July just around the corner and boat still isn't in the water!
I've tried connecting the tach wire to the primer position on the key switch and nothing.
I've tried running a separate wire from the key switch to the primer solenoid and nothing.
I've cleaned all the connections including the engine grounds and nothing happened.
I've checked the inline 20 amp fuse and it is not blown.
I am completely puzzled it started and ran perfectly only 2 weeks ago!
Honorary Supreme Mariner
This proves that when wires are involved it becomes confusing.---When you hooked the tach wire up at the switch what did you do at the other end of the tach wire ?
dinghyracer
I connected the other end of the tach wire to the live wire on the primer solenoid
dinghyracer
Yes it still works when I take a positve and negative wires straight from a battery to the solenoid.
Bosunsmate
well you need to work back by putting 12v on the end of the tach wire in the control box to check that ok, then check you have 12v at the key switch when you press it in.
dinghyracer
Ended up bringing it to a mechanic he fixed it in only a few minutes after determining that there was 12v on the live wire and the grounds were good! He explained that the bracket that holds the solenoid in place was to tight and effecting the flow of current. He made a small piece of metal to place between the solenoid and the engine block and put washers on the bolts so that it was not being squeezed into the engine by the bracket. It seems to be clicking all the time now :) let's hope this solves the problem for good!
Thanks guys for all your input greatly appreciated
dinghyracer
Update:
Boat has been in the water now for a few weeks and had been running pretty good since I got the primer solenoid fixed.
Today I went to go out and the Engine was a pain to get it started. The primer was working, It had good fuel and battery is charged up. It just kept cranking over and occasionally it would catch enough for the starter to disengage but would not keep running. I took off the cover and held down the throttle adjustments to get it to start up eventually. It cut out on me twice in the first few minutes once I got it running but started right back up after and was fine for the rest of the day :/
Greg
