hooterville
Thread starter- Joined
- Feb 18, 2007
- 74
Ok took my new boat and old 1990 48hp Johnson out today. Ran about 28-29Mph with wife and little girl in there. Pretty good i thought. Gonna have to do a little adjusting to get idle right on engine when throttle is in neutral. Other than that ran great.
One question i have is that when you squeeze the ball on fuel line a couple of times to pump up gas to the carbs there was gas coming out of a little mesh port on the top side of carb(s). Is this normal? I probably squeezed ball too many times.
I was switching fuel lines between my kicker motor and 48hp as well as tanks when i noticed gas smell at ramp.
Another i have my 48 hp engine setting on a cmc pt130 tilt unit. When going down the lake i noticed water spraying up almost into the back of the boat and all over the kicker. That is with engine trimmed down, if i trimmed it up a little ,water didn't spray as much. I don't have a tach on the motor to know rpm's and don't have a gauge on the cmc unit, just visual. I'm thinking the more trimmed up the more rpm's. Don't wanna blow it up.
