Maverick49
- Jun 4, 2007
- 28
Ok so I go to my local marine shop to see about a water pump kit, he says I do not need any gaskets when I replace the impeller maybe a couple O rings if they look bad. I tell him that when I changed the lower unit gear oil that there was a bit of water present, not alot, but some signs of water in the oil. He says that it maybe just the O rings on the "fill & drain plugs" that are worn out. Also he ask's about the pee hole, if it's shooting a good stream then I don't need a new impeller. Can anyone tell me if this is correct? also can I do this impeller change with just basic tools or do I need anything special? I do have a OMC manual that will help me.
