1990 40 hp johnson surging
nathansr06
I have a 1990 Johnson 40 hp pushing an 18 foot pontoon. I was first having an issue with it only getting up to about 3500 rpm and then dropping back down to 2400 pms or so. it would run fine until I gave it more than half throttle. I checked compression and it was 131 in the top cylinder and 135 in the bottom. I have rebuilt both carbs, replaced every fuel line, new fuel tank, new plugs, I am getting good spark on both plugs. I have tried pumping the fuel ball when it acts up with no change. I have tried choking it when it acts up with no change. I have pulled the plug wires one at a time and when I pull either one it dies. when I took it out yesterday I would give it full throttle and it would jump to 4500 rpms and then surge down to around 3000 and go back and forth a few times before stalling out. it always starts right back up and idles great and runs good until I would get past 1500 rpms or so. im at a loss right no for what the problem is. any help is appreciated. thanks!
boobie
Try squirting some fuel in the carb throats when this happens and see what it does. You may have missed something in your carb repair.
nathansr06
Ok. I didn't think of that! I will give that a try tomorrow. That would really narrow down my culprit!
When you try choking / priming the motor when it is running you should hear a change in operation of the motor.-----This indicates that the fuel pump may not be working correctly.---Easy to inspect.
Tulsa_Tank
I had a surging problem on a 70hp and i found material from the old fuel lines clogged up the connection at the motor didn't see it after i replaced the lines. I could pump the bulb when it was acting up and nothing would happen because of that.
