Relative newbie here.
Recently purchased a 1990 Larson All American 170 with a Mercruiser 3.0 Litre I/O (Model MCM 3.0 Litre W/DDIS.
When I got it, I couldn't get it to turn over. Noticed that 3 of the 4 spark plugs were unplugged (spark plugs were replaced this spring). Plugged those in. Dropped it in, boat would crank but not turn over, and then power to everything was gone. Figured it was the battery, so got a new battery. Hooked everything up, put it on muffs, got it running. Took it to a lake the next day, dropped in, turned over once but only stayed running for like 5 seconds, then died. No power to gauges, switches; nothing happens when key is turned. Trim works, but only down and trailer. No up.
Don't know if this is relevant, but boat worked all last summer. Spark plugs were replaced this spring. Trim reservoir, solenoid, and fuse were also replaced this spring. Says that system was tested and everything worked.
I'm stuck. Not sure where to look both in terms of why nothing is getting power now even with battery charged, and what could be draining it while it sits. Help!
