1990 25hp out board info
Avasis
Just picked up a 90 sea nymp with a Johnson 25 hp outboard any tips or things to look out for ?? Motor runs just never owned a 2 stroke outboard before so just getting some heads up
Thanks !
Mi duckdown
Re: 1990 25hp out board info
If it where mine. I would change the lower end lube, and install a new water pump impeller. atleast
Avasis
I tried yesterday to get the screws loose for the lube there so tight I can get them loose where is the impeller for the water pump?
jasper60103
James R
Jasper should have said impact screwdriver. The impeller is mounted on the top of the lower unit with the drive shaft going through it. You will need to remove the lower unit. Has this motor been used in salt water?
Avasis
Never in salt water been in Wisconsin all its life untill now i did look up how to replace it doesnt look to bad
James R
The reason for the salt water question was to caution you on bolt removal. With it being a fresh water beast you should have no problem. However if the bolts appear to be reluctant you may need to use heat. These small bolts have a habit of shearing. When you refit the pump and the lower unit paint the bolts, including the shanks, with OMC gasket sealer. Life will be easier later.
