1990 225 thermostat update, need help
rte203
Hello guys, I know this has been coverd before, but I need help if somebody could. Im in the process of updating my thermostat due to the water control valve being no longer avaliable.
I have the parts list,
2) 0333858 springs
(2) 0333967 covers
(2) 0329830gaskets
(2) 0394409 t-stat assy or
(2) 0394411 veratherms 140?
I just dont uderstand where the spring goes.
I took mine apart, and i dont see a spring,
Can anybody help?
flyingscott
The springs hold the thermostat down against the seat. If they were not there the waterpump pressure at an idle would push the thermostat away from the seal and the engine would run cold. The spring allows the the thermostat to seal the water passage and forces the engine to warm up faster by restricting the flow. This allows the thermostat to open and let water through to the rest of the motor. By doing that the temperature is regulated better at an idle. As the motor speeds up the pressure from the pump overcomes the spring and pushes the thermostat away away so more water can flow to the motor when it's needed.
rte203
Thank you flyingscott, I know it may have been a dumb question. But I dont like to buy parts if I dont know. Thanks again
