1990 200 evinrude starting problem
leifer
Just had a rebuild on the motor. Motor started about 20 times in yard while I did some boat repair. I'd let it run about 3-4 minutes each time. The last 4 times I have started to crank it, I had no spark on any cylinder, I'd continue cranking and finally without doing anything I'd get spark and it would crank. After it cranked the first time for the day, it would be crank fine, just with a touch of the key! Go out the next day and the same problem, when I'd try to crank no spark, and again finally spark and fire off and good to go again, this happens after sitting overnight, anyone know why I don't get fire after sitting a few hours, and then after continue cranking it will fire?
jtexas
Re: 1990 200 evinrude starting problem
first step, rule out an intermittent short to ground in the kill circuit, by disconnecting the black/yellow kill wire at the powerpack and repeating your spark test.
leifer
Already tried, checked all other kill circuts, thats not the problem, any other suggestion. Thanks
wilde1j
No spark any cylinder? Have you checked shift interrupter sw? I think your motor has one ... kills one bank during shifting. Would make it hard, but not impossible to start if misadjusted.
leifer
Haven't checked or know I've got one, but you state it kills one bank?? I've no spark on either bank when I first try to start.
wilde1j
If above doesn't clear it, try:
Six Cylinder Engines
(1988-2000 185-250 HP Quick-Start Models)
Service Note: Please use the Factory recommended spark plug (currently Champion QL77JC4) gapped at 0.030?.
(Note) These engines usually have a 35 Amp battery charging capacity. Due to the size and weight of the flywheel magnets, it is highly
recommended that you check to make sure both the triggering and charge magnets are still secure in the flywheel before you service the engine.
A loose or broken magnet can be deadly to you or your pocketbook. It is a recommended you index the flywheel and check the timing on all
cylinders when servicing these engines. Also check for static firing and intermittent spark.
NO SPARK ON ANY CYLINDER:
1. Disconnect BOTH of the Black/Yellow stop wires AT THE POWER PACK and retest. If the engine's ignition has spark, the
stop circuit has a fault. Check the key switch, harness and shift switch.
2. Disconnect the Yellow wires from the stator to the rectifier and retest. If the engine sparks, replace the rectifier.
3. Check the cranking RPM. A cranking speed of less than 250-RPM will not allow the system to spark properly. This can be
caused by a weak battery, dragging starter, bad battery cables or a mechanical problem inside the engine.
4. Inspect and clean all engine and ignition ground connections.
5. Check the stator and timer base resistance and DVA output as given below for BOTH banks:
WIRE READ TO RESISTANCE DVA (Connected) DVA (Disconnected)
Brown Brown/Yellow 900-1100 (35 amp) 150 V + 150 V + (*)
Orange Orange/Black 93-103 11-22 V 45-120 V (*)
White Purple (c) 100 V + (a) 0.6 V + (#)
White Blue (c) 100 V + (a) 0.6 V + (#)
White Green (c) 100 V + (a) 0.6 V + (#)
White Purple (2nd connector) (c) 100 V + (a) 0.6 V + (#)
White Blue (2nd connector) (c) 100 V + (a) 0.6 V + (#)
White Green (2nd connector) (c) 100 V + (a) 0.6 V + (#)
White Black/White (2nd connector) 215-225 6-12 V (b) 6-12 V (from pack)
(*) This reading can be used to determine if a stator or pack has a problem. For instance, if you have no spark on any cylinder and the
stator?s DVA reading is out of spec ? disconnect the stator wires and recheck the DVA output. If the reading is still out of spec ? the stator
is bad. If the reading is now within spec ? the pack is bad.
(#) This reading can be used to determine if a pack has a problem in the triggering circuit. For instance, if you have no spark on one
cylinder and the timer base?s DVA reading for that cylinder is low ? disconnect the timer base wires and recheck the DVA output. If the
reading stays low ? the timer base is bad. If the reading is now within spec ? the pack is bad.
(a) Check stator DVA first. Then if timer base DVA is 0.6 - 1.5 V, the pack is faulty. If below 0.6 V or 1.5 - 99 V, the timer base is faulty.
(b) DVA will drop below 1 V when the engine drops out of Quick-Start (engine is over 104 Degrees or 1200 RPM).
(c) Use a comparison reading as different brands of meters will give different readings. The typical range is 1M to 5M ohms. As long as
you have approximately the same ohm reading on all six tests and the correct output with the DVA meter, the timer base should be good.
Remember that temperature will affect the readings. The exception would be if one of the SCR?s inside the timer base is breaking down
while the engine is running. This can be found indexing the flywheel and checking the timing on all cylinders. If the readings are off,
reverse the meter leads and retest to see if the readings are corrected.
6. Check the center hub triggering magnet in the flywheel. A loose magnet can cause this problem.
7. Check the triggering and charge coil flywheel magnets for cracked, broken and loose magnets.
NO SPARK OR INTERMITTENT SPARK ON ONE BANK:
1. Disconnect BOTH of the Black/Yellow stop wires AT THE POWER PACK and retest. If the engine's ignition now has
spark, the stop circuit has a fault. Check the key switch, harness and shift switch.
2. Swap the stator wire pairs from one side of the engine to the other side and see if the problem moves. If it does, the stator is
bad.
3. Disconnect the Yellow wires from the stator to the rectifier and retest. If the engine sparks, replace the rectifier.
4. Check the cranking RPM. A cranking speed of less than 250-RPM will not allow the system to spark properly. This can be
5. Check the stator resistance and DVA output for BOTH banks (see NO SPARK ON ANY CYLINDER above).
6. Check the DVA output on the Orange wires from the power pack while connected to the ignition coils. You should have a
reading of at least 150V or more. If the reading is low on one bank, disconnect the Orange wires from the ignition coil for
that bank and reconnect them to a load resistor. Retest. If the reading is now good, one or all of the ignition coils are likely
bad. A continued low reading indicates a bad power pack.
NO SPARK OR INTERMITTENT SPARK ON ONE OR MORE CYLINDERS:
(NOTE) These engines use a gear reduction starter which results in a lower cranking RPM than usual. If you have one or more
cylinders intermittent at cranking: Try starting the engine and checking to see if ALL of the cylinders now spark correctly. If so,
the engine?s ignition should be good. Make sure the battery is sized correctly as the cranking capacity can affect the cranking
speed.
1. Check the timer base resistance and DVA output (see NO SPARK ON ANY CYLINDER above).
2. Check the DVA output on the Orange wires from the power pack while connected to the ignition coils. You should have a
reading of at least 150V or more. If the reading is low on one cylinder, disconnect the Orange wire from the ignition coil for
that cylinder and reconnect it to a load resistor. Retest. If the reading is now good, the ignition coil is likely bad. A continued
low reading indicates a bad power pack or timer base.
All rights reserved. Reproduction or use of content, in any manner, without express written permission by CDI Electronics, Inc., is prohibited. Rev A 2/2010
3. Check the power pack resistance given below:
Wire Color (CYL) Check to Wire Color Resistance
Orange/Blue (#1) Blue (in 4 pin connector with Black/White wire) 110 (a)
Orange (#3) Purple (in 4 pin connector with Black/White wire) 110 (a)
Orange/Green (#5) Green (in 4 pin connector with Black/White wire) 110 (a)
Orange/Blue (#2) Blue (in 4 pin connector with White wire) 110 (a)
Orange (#4) Purple (in 4 pin connector with White wire) 110 (a)
Orange/Green (#6) Green (in 4 pin connector with White wire) 110 (a)
White Black (Engine Ground) Shorted
Brown Black (Engine Ground) Open or M range
Brown/Yellow Black (Engine Ground) Open or M range
Brown/White Black (Engine Ground) Open or M range
Brown/Black Black (Engine Ground) Open or M range
(a) Use a comparison reading as different brands of meters will give different readings. The typical range is 90 to 150 ohms for the Orange
wires. You should have approximately the same ohm reading on all six tests with the Orange wires. If one of the SCR?s inside the power
pack is shorted or open, the readings will be quite a bit different.
4. Check the spark plug wires for breaks and abrasions.
5. Visually inspect the ignition coils for burned or discolored areas and cracks in the casing (indicating arcing inside the coil).
6. Swap the ignition coil with one that is sparking correctly.
7. Rare causes include a weak trigger magnet. If possible, try another flywheel.
POWER PACK OR TIMER BASE REPEATEDLY BLOWS ON SAME CYLINDER:
1. Check the timer base wires for shorts to engine ground as a shorted timer base wire can destroy a SCR inside the power
pack.
2. In contrast, a shorted SCR inside the power pack can destroy a timer base coil. Check the timer base resistance and DVA
3. Replace the ignition coil on the cylinder dropping spark.
ENGINE WILL NOT SHUT OFF:
Disconnect the stop wires at the power pack. Connect a jumper wire to the stop wires from the pack and short it to engine ground.
If this stops the pack from sparking, the stop circuit has a fault. Check the key switch, harness and shift switch. If this does not
stop the pack from sparking, replace the power pack. Repeat test as necessary for additional packs.
MISS AT ANY RPM:
1. Disconnect the Yellow wires from the stator to the rectifier and retest. If the miss clears, replace the rectifier.
2. In the water or on a Dynameters, check the DVA output on the Orange wires from the power pack while connected to the
ignition coils. You should have a reading of at least 150V DVA or more, increasing with engine RPM until it reaches 300-
400V DVA maximum. A sharp drop in DVA right before the miss becomes apparent on all cylinders will normally be
caused by a bad stator. A sharp drop in DVA on less than all cylinders will normally be the power pack or timer base.
3. Connect an inductive tachometer to each cylinder in turn and try to isolate the problem. A high variance in RPM on one
cylinder usually indicates a problem in the power pack or ignition coil. Occasionally a timer base will cause this same
problem. Check the timer base DVA voltage (see NO SPARK ON ANY CYLINDER above).
4. Perform a high-speed shutdown and read the spark plugs. Check for water. A crack in the block can cause a miss at high
speed when the water pressure gets high, but a normal shutdown will mask the problem.
5. Check the triggering and charge coil flywheel magnets for cracked, broken and loose magnets.
6. Rotate the stator one bolt hole in either direction and retest.
ENGINE WILL NOT ACCELERATE BEYOND 2500 RPM (Runs smooth below that RPM):
1. Use a temperature probe and verify that the engine is not overheating.
2. Disconnect the tan temperature wire from the pack and retest. If the engine now performs properly, test and replace the
defective temperature switch.
3. Make sure the tan temperature switch wire is not located next to a spark plug wire.
4. Disconnect the VRO sensor from the engine harness and retest. If the engine performs correctly, replace the VRO or sensor.
ENGINE DIES WHEN QUICK-START DROPS OUT:
Check ignition timing at idle with the White/Black temperature wire disconnected. Remember to allow for the drop in ignition
timing when Quick-Start disengages. Verify ignition timing after engine has warmed up, according to the service manual.
ENGINE STAYS IN QUICK-START:
1. With the engine idling, check the Yellow/Red wire for DC voltage. If there is DC voltage over 2 volts on this wire while the
engine is running, the Quick-Start will not disengage. A voltage of 5 to 7 volts will not engage the starter solenoid, yet will
engage Quick-Start.
2. Short the White/Black temperature switch wire FROM the power pack to engine ground. Start the engine, if the Quick-Start
drops out after approximately 5 seconds, replace the White/Black temperature switch.
3. Disconnect the Black/White wire from the power pack. If the Quick-Start feature is not now working, replace the power
pack.
Johnson/Evinrude Troubleshooting
ENGINE WILL NOT ENGAGE QUICK-START:
1. Disconnect the White/Black wire from the temperature sensor.
2. With the engine idling, check the Black/White timer base wire for DC voltage. There should be about 6 to 10 volts DC
voltage on this wire while the engine is running for the Quick-Start to engage.
3. Short the White/Black temperature switch wire FROM the power pack to engine ground. If the voltage on the Black/White
wire drops out after approximately 5 seconds but the engine timing does not change, replace the timer base. If the voltage
remains present, disconnect the Yellow/Red wire to the pack and repeat the test. If the voltage still remains, replace the
pack.
ENGINE TIMING TOO HIGH:
1. Check the flywheel center hub magnet to make sure it?s tight. Look for signs of cracks and bulges in the Brown ferret
magnet material.
2. Short the White/Black temp wire to engine ground and see if the timing drops back to normal.
3. Check the DC voltage on the Black/White wire going to the timer base. With the White/Black temp wire disconnected, the
voltage should be 6 to 10 volts. When the White/Black temp wire is shorted to engine ground, the voltage should drop out.
If the voltage on the Black/White wire stays in the 6-10 volt range, disconnect the Yellow/Red wire from the power pack.
The voltage should drop out on the Black/White wire. If it does, the harness or starter solenoid is likely defective. If the
voltage on the Black/White wire stays in the 6-10 volt range with the Yellow/Red wire disconnected and the White/Black
wire shorted to engine ground, the power pack is defective.
If you don't have a DVA peak picker, try here:
http://www.usatoolwarehouse.com/usatoolwarehouse/ESI-530-p-ESI.html
leifer
Thanks Jim, I guess I''ll start on testing and see what happens.
Pokertrampp
Service Note: Please use the Factory recommended spark plug (currently Champion QL77JC4) gapped at 0.030?...........
Would this be the same plugs and procudure for a 4 clyinder? (1988 120hp Johnson)
wilde1j
No ... start your own thread, rather than hijack if you have a problem.
Pokertrampp
already have and i was not trying to hijack just asking a question about somthing already being discussed.
