If you dont have continuity, as in the wire has an open, or break in it, that is your issue. The motor shuts down by the blk/yel going to ground.
Please forgive me if i am understanding you incorrectly.
A way to test would be to ground the blk/yel at power pack. You should have no spark then. If yoi do have spark with blk/yel grounded at pack then suspect bad ground circuit or bad pack.
Speaking of that, are your battery canles tight? Like with a wrench tight?
