Hi all.
I've doing some work to my 1991 15hp Johnson outboard and wanted to take a stab at replacing the two grommets found at the top of the exhaust housing due to lighter than normal pressure from the pee indicator.
Now, I've ordered the grommets and gasket and moved forward with pulling the powerhead. I've detached the exhaust tube to find a couple of swollen grommets. The part I'm struggling with, is the order on how to install these grommets.
These grommets don't have much play to them and the lip around the top of the copper tubes aren't helping. Am I supposed to slide the grommets onto the lip found on top of the water tubes, then attempt to slide the bottom of the water tube through the opening on the top of the exhaust housing? Or am I supposed to seat the grommet into the exhaust housing first on its own, then try forcing the water tube through the exhaust housing and into the grommet?
I've tried both ways with A Lot of marine grease without much success. Does anyone have any tips on how to install?
