1990 120 evinrude looper unknown problem
leifer
My 1990 120hp evinrude looper is on a 18 foot Javelin. I am having a problem about 50 percent of the time when trying to get it out of the hole. The motor runs good on top end, 56mph, idles great. but half the time when I give it the gas it like it bogs down and won't hardly get out of the hole and the ther half the time it jumps right up? I have a 22 pitch raker prop. I even tried some hydrofoils with same results. Any ideas?
diver_down
Re: 1990 120 evinrude looper unknown problem
did you do any maintenance on it recently?
compression numbers?
71Windsor
sounds to me like a fuel problem. when it bogs down have you checked your primer bulb? make sure its staying firm. i would start by changing any fuel water separator and primer ball. then move on to a carb cleaning if that hasnt been done in a while.
jonesg
Hit the choke when it starts bogging, if it picks up the carbs are getting clogged. If not then I'd do a spark test, should jump 3/8th inch gap.
Got a water seperator, keep it clean?
Brew2
Agree with Jonesg...fuel delivery. If the motor recovers immediately after bumping primer then start checking for clogged carb jets, air leaks in fuel system connections, kinks in fuel lines (particularly the small ones running to each carb), etc.
Something is preventing enough gas from getting to one or more cylinders.
wilde1j
The primer ball does not "stay firm", it just should not collapse. It's only firm while squeezing.
ezeke
That's a lot of prop for the 120HP motor on most 18' Javelin boats, which are heavy.
What's your RPM at WOT?
