1990 115 Evinrude Power Pack
vinboy
1990 115 Evinrude losses power under load. In nuetral took the boots off the plugs in succession and found no loss in RPM for two plugs on the left side of motor. Switched wires and plugs from functioning side and had same result. While removing plugs on the left side on both cases I got shocked. No shock on the right side using plyers with electrical tape on handles and tips. Is this a power pack problem? If so why is only one side effected given this motor I beleive has only one pack. thanks for the help.
