Re: 1989 yamaha 90 hp compression question
Several ways to do the decarbon, but I would use a quart of the Yamaha Ringfree and use it in your gas tank at the "deposit removal" dosage, go out on the lake or river and run your motor at various RPM's. Check spark plugs for fouling which can occur during decarbon process. You should consider using the Ringfree all the time at the "deposit prevention" dosage. You can purchase Ringfree online or from your Yamaha dealer. Good Luck!
