1989 yamaha 50hp wont trim under load
Daiviee
My outboard tilts up and down just fine until I give it some gas then it wont trim up. Out of the water it will go all the way up and down but if I put any pressure on the prop it will not go up. The trim motor still runs and changes sounds like its under pressure but never quits running. Could the fluid be bad? Could there be air in it? If it was low I wouldn't think it would lift all the way up but it does. Anyone have any ideas
99yam40
your motor is not a power Tilt and trim, it is just a power tilt
Daiviee
That sounds about right. I noticed it only had one speed on the little motor. But it didn't dawn on me till you said that. Thank you very much.
99yam40
the complete model of the motor will tell you what options it has
