1989 V200 water in cylinder
jtecker
I have a 1989 V200 Black Max. Water is getting into the #6 cylinder. Replaced the head gasket but did not solve problem. Is there another possible source for the water other than a cracked block? Could a leak on the exhaust manifold gasket on this engine allow water into a specific cylinder? Any help/ideas would be certainly welcome. Hoping the block isn't toast. Thanks.
Faztbullet
Re: 1989 V200 water in cylinder
A leaking divider plate can sometimes cause this but usually #5 will show water also..
jtecker
Pulled the divider plate last night. The back gasket appeared to be compromised on the bottom. The exhaust port on #5 cylinder did have some of the foamy water/fuel mix in it as well. Good call. Will update once both gaskets replaced. Fingers are crossed that is the problem! Thanks very much for the post.
jtecker
I replaced both divider plate gaskets. No water in #5 but am still getting water in #6. Inspected the divider plate very closely. Didn't see any damage. So the head gasket and divider plate gaskets have been replaced but am still getting water into #6. Other possibilities? Could a bad reed cause this?
Faztbullet
If a pedal is missing ...yes. If a steel sleeved block look around edge and see if aluminum is pulling away from sleeve.
jtecker
Solved the water problem in #6. Faztbullet thanks very much for your insight. Now I have another problem. At full throttle the engine only gets to about 2800 RPM's. Doesn't sound like all cylinders firing. Cruising along at that speed after 5 or 10 minutes it seems like other cylinders are trying to kick in. The boat jerks forward when this happens. Keeps trying to kick in. Once it did kick in and the engine jumped to 4300 RPM's and was smooth. Can not figure out seems like all cylinders not firing under load. In the driveway all cylinders have spark. Carbs were just rebuilt. New fuel separator/filter. All new fuel lines. Seems electrical. Would an entire side of cylinders not be working under load? Maybe switchbox? Boat is a 1977 Mako 23. Not sure if the engine would even get to 2800 with the boat partially on plane with just 3 cylinders. Thanks in advance for any suggestions on what to test/check.
